Leaking from flow valve connection
A new flow valve was replaced a year ago and now the water connection pipe that fits into the bottom of the tank is leaking. I checked to see if the connection was tightened; it was tightened suffuciently. What's the best way to fix this problem? We had considerable water damage in the basement from the undetected leak.
Thank you in advance.
Diana
Diana
The non-pro way (but it works) is to turn the water off, take the nut loose, smear a little silicone caulk on around it, and tighten it back up.
Good Luck!
Good Luck!
