loss of hot water pressure after fitting new bath/tap/shower fitting
Old 09-25-02, 09:26 AM
mjwdotcom
Hi, i recently fitted a new bath tap, shower /combined fitting, and since fitting it, i have lost pressure in the hot water taps and shower , can anyone advise me what the problem might be?
Old 09-25-02, 08:45 PM
Plumber2000's Avatar
Are you saying you replaced the whole valve?
Old 09-26-02, 08:26 AM
mjwdotcom
Hi again,
in reply to your question,"did i replace the whole valve", what i did was this? = I disconnected both the hot and cold bath taps, turning off hot and cold water first,, and replaced these taps with a bath/mixer/shower unit, it was simply a case of , turning of water, disconnecting, fitting new tap/shower/mixer unit, and reconnecting the hot/cold pipes back to the appropriatetap, then turning hot/cold water back on, but since i ve fitted this unit, the hot water pressure is visibly less coming from all hot water taps in the house, and if i try to use the shower part of the mixer unit, there is little or no hot water comes through the shower attachment, due to poor hot water pressure, i ve checked the mixer unit out thoroughly, and it s fine.
Thank you for responding to my query
regards, Mjw dot com
Old 09-26-02, 09:26 AM
Do you have galvinized pipes in the house?
Old 09-26-02, 11:10 AM
mjwdotcom
lack of hot water pressure
All pipes in house are copper .
Thank you once again for replying,
mjwdotcom.
Old 09-26-02, 12:13 PM
Make sure off valves are fully open.
Sounds like debrie is in the line, you need to try and flush each fixture out one at a time, only thing I can think of.
Old 09-26-02, 12:59 PM
mjwdotcom
Ok, i hear what you re saying, and having checked all else out too, i think you reprobaly right, i ll try and flush out the line, as you say,
Once again ,thank you for your advice, and support,
regards, mjwdotcom
