Cutting Pipe
Cutting Pipe
I have the remains of what I believe is an old steam heating system in my 80+ year old house. There is a U section of pipe running the length of the basement I want to remove.
The pipe is 2 1/2 inches in diameter and 1/4 inch think. I've estimated I'll need to make approximately 8-10 cuts to remove. The pipe has cuts where the boiler was taken out and the cut is freakishly uniform as if done with a standard pipe cutter
What's the best way to cut through the pipe and am I going to go through a lot of blades?
Thanks!
Pauly
Thanks!
Pauly
