Lateral Sewer line question- tie-in and/or insert
Old 10-16-02, 05:50 AM
bnowatzk
I have a cracked cast iron 3 inch lateral main line that I have dug up in my basement. I have reached the point where it connects to 6 inch clay under the house foundation. I have two questions:
1) From a video, I know that the clay pipe has roots at the joints and I am wondering if while I am replacing the inside pipe, if I can insert (ie, shove from the basement toward the street) 4 inch PVC from the basement to the city line. This is about 30 feet. The obvious advantage is that I would not have to eventually dig up the yard.
2) I assume that there will be several comments on why option #1 is not recommended. So, what is the method for connecting the 4 inch PVC to the existing 6 inch clay? It appears that the current cast iron is sealed with cement of some kind, although, tree roots have broken through this.
Thanks for your help.
Old 10-16-02, 06:09 AM
Plumber2000's Avatar
Your right not recommended, replacement of a sewer line needs to be permited, means you have to dig out the entire line, make proper connections, and get it inspected.
Sorry I won't tell you it's ok to do it that way.
HTML code is On
