stupid toilet
stupid toilet
We have replaced the flapper twice in our toilet and it will not float when we flush so we have to hold down the handle to flush completely. The chain is tight, the water level is right. Does anybody have any suggestions? Help!!!
Received 1 Upvote
1 Post
If your flapper is attached to the overflow valve by a rubber ring (and has two little rubber "ears"), and your overflow valve has two little L-shaped brackets at the bottom, cut out the rubber ring and attach the flapper rubber "ears" to those little brackets.
It'll work better like that sometimes.
Good luck!
Mike
Good luck!
Mike
