Plumbing
We just repaired the main sewer line in our home. Everything was working perfect. We used a snake throughout the pipes to make sure there were no clogs anywhere. Our home is a duplex and the house next door does have trouble with their kitchen sink, but then that house always had a little trouble with the kitchen sink. But our side was working perfect. But then the next day the toilet wasn't flushing right. You can hear air through the kitchen sink when the toilet does flush (which is occasionally). Our house is very, very old.
Is there anyone out there that can help us?
There is a trap and there is vents. Also, my husband said that when we drain the tub, he hears bubbles in the toilet.
When we used the snake the day before yesterday on the house next door,it had an attachment at the tip,and when we pulled it out, the tip was broken off. Can that be the problem? Do you think we should snake it again?
Thank you for replying.
How do we find out if there is a whole somewhere else? The way we found this out was because the pipe is in the front yard under dirt. A good 90% of the yard is cement.
Again, thank you so much for your replies.
I am leaving work in about 2 minutes and I don't have a computer at home so I won't be able to get this answer until Monday. So far what you've given me is greatly appreciated.
Thank you.
Thank you.
