Clogged Toilet
Old 11-25-02, 06:46 AM
dottott
Clogged Toilet
Hi. I dropped a stick deoderant into the toilet while it was flushing (by accident!) It went down and I don't know how to get it back out. So far I've tried a plunger and it drops the water level but no sign of the deoderant. Thanks for the help!
Old 11-25-02, 07:47 AM
Plumber2000's Avatar
Get a toilet anger, these stick deoderant can be a pain to get out.
Sometime I'll remove all the water out of the toilet bowl and run the auger, this way if the object is a floating object and it decides to drop back to bowl, it can't float back up into bowl passage way.
Who know maybe before you buy a auger remove the water and see if the object just might happen to drop down.
Last resort is to pull the toilet if all else fails.
Old 11-25-02, 02:28 PM
dottott
Hi. Thanks for the advice. I tried the things you suggested. I called a plumber friend of mine and he had to take the toilet apart to get it out. Now it's put back together and working fine! Thanks for the quick advice!!!
HTML code is On
