no/low water Pressure for kitchen sink
The water coming out of the faucet of the kitchen sink is coming out with little or no pressure behind it. I've already unscrewed the sreen thing and cleaned that out and it still runs the same. The weird thing is that the sprayer hose attached to the sink works fine and the water comes out at normal pressure. Any tips or advice on the faucet will be much appriciated!!
Well since you say you have stong flow to the sprayer and you cleaned out the areator, then there muct be a problem passing water through to the spout, turn water off under sink, you need to remove the spout, once removed, put towel over the faucet body, turn each valve back on for a few minutes, and make sure the port to the spout are clear, afterwards reinstall the spout and see it that fixed the problem.
Regarding the low water pressure from your peerless kitchen faucet, I have the same problem with my peerless faucet only it is the hot water side that has low pressure and not so much the cold water side. I have taken mine apart but see nothing wrong with it. Everything appears to be clear and I have plenty of water pressure without the faucet hooked up. I am interested in what you find to be the problem.
I don't know much and don't care for peerless faucets, if all else fails, you can get a good Moen Kitchen faucet for under $100.
I'd install a new faucet if the problem can't be resolved.
