vanity drain
vanity drain
replacing drain underneath bathroom vanity. Inside the wall is steel i believe. I want to go back with ABS. Can i just tread the ABS into the steel fitting or do i use tape for the treads.
If you have female thread inside that wall you can use a male adaptor like this one
Then use abs pipe and a trap from there.
Use teflon tape or pipe dope on the male threads.
