Cold Water Supply uunder Concrete
Cold Water Supply under Concrete
I am planning to run cold water supply line under the driveway. What is the IRC/UPC restrictions or code regulations regarding running cold water line under the concrete?
Same here in GA... we use pvc underground for service lines mostly and only have to be 12" deep... But check your local codes for special cases like going under a driveway... If I go under a parking lot, I have to go 3', but I think you can get away with 2' under a driveway...
