faucet
Old 01-07-03, 05:28 AM
NMDickens
faucet
I had a new sink and faucet installed yesterday in the bathroom and the controls seem to rotate in the opposite direction as one would think (clockwise to turn on instead of counterclockwise). Is there anything I can do?
Old 01-07-03, 05:10 PM
Ragnar's Avatar
Turn the water off, take the handles off and first check to see of the handle orientation can be changed to make the difference, if not take out the stems and swap sides... If they both turn the same way, you may also just need to flip the stems around in the same hole.... Just experiment with the different orientations of stem and handle and see what you come up with...
HTML code is On
