Kitchen Faucet Vibrates.........
Old 01-31-03, 12:21 PM
phoenix22
Whenever water is called for .....either hot or cold........the kitchen faucet jumps around/vibrates 3 or 4 times before it settles down........I'm suspecting the actual faucet, because it does it for either hot or cold.....but I am not sure. It does not matter whether the aerator is attached or not........the faucet is about 6 years old and is a water fall Delta......(not sure on the Delta).....I said Delta, because all the other fittings in the home are Delta........the home was certified for occ in Dec 96'. Any thoughts?? jd
Old 01-31-03, 12:36 PM
Mike Swearingen's Avatar
Cool
Sounds like you need to replace the seats-and-springs.
You can do a Search above for Delta Faucets for the how-to.
You can also visit:
http://www.deltafaucet.com/custserv/faucet_repair.html
Good luck!
Mike
P.S. De Opresso Liber. (Was in SF back in 67 myself.)
And at just about exactly this time 35 years ago, I was TET68ing it, but not in SF. Those were interesting times, too. LOL
Old 01-31-03, 01:05 PM
phoenix22
All right will check that out.........and thanks. Worked in N'Trang and Saigon for the 3rd studies and observation .......then in beeeeeeeutiful downtown Hue Feb 68 with the 101.....hence the call sign .........phoenix22..........out of evans
Old 02-10-03, 03:47 PM
phoenix22
ok here is something to remember...........first, it was a delta waterfall ........twin handle.........with and this is the key........... it has a sprayer........would you believe a probable piece of solder........clogged the diverter for the sprayer.........since the home isn't that old and I bought it from a single builder.......he probably never noticed.......I always thought the pressure was slow or low............anyway replaced the 5$ diverter and got a spare......bingo........no jumping and plenty of water.....here endth the lesson.......
HTML code is On
