Leaking kitchen faucet
Old 02-13-03, 10:49 AM
Hardwork18
I tried to repair my single lever kitchen mixer. It leaked very sligjhtly. It is a Kludi with a sprout/spray head connected through a hose. Having loosened the tiny hexagonal screw behind the blue/red plastic stud below the lever, and the larger slot screw at the back of the base of the faucet, the lever did not loosen or come off. These are the only screws I could find. What is the trick? What shoulkd I do?
Old 02-13-03, 07:14 PM
Ragnar's Avatar
I believe the screw behind the plastic stud is all that was required... How long has the handle been on without having been removed? Sometimes, after the screws are out, you may still have to use a handle puller (or some good old-fashioned brute force) to get the handle off... But I am not very familiar with the brand, so it may be time to send you to the website... www.kludi.de ... You will have to switch the language to english with the link at the top (unless you speak german), and then register with your email addy to get full support, but it appears pretty comprehensive...
Old 02-13-03, 07:41 PM
Plumber2000's Avatar
Kludi is an import faucet, from Germany.
Are you from there?.
Can't read it so, my research will do no good.
Old 02-13-03, 07:56 PM
Go here and see if any of these faucets might be yours.
Kludi
HTML code is On
