No water in toilet tank
Old 02-16-03, 11:17 AM
pawmer2
Exclamation No water in toilet tank
The water in the toilet bowl does not flush--there is no water in the tank. I've checked the on/off valve and it is open.I do not hear running water and the water pressure from the sink faucet is fine.Any ideas regarding the cause/solution???
Old 02-16-03, 12:47 PM
Either the shut off valve or the fill valve is clogged. Turn the water off at the shut off and disconnect the supply line at the bottom of teh toilet tank. Aim that supply line into a bucket or a bowl and open the shut off valve. If you get water flowing, the shut off valve is fine. Replace the fill valve with a Fluidmaster 400A.
Old 02-16-03, 07:00 PM
Ragnar's Avatar
Sounds like another frozen pipe... How has the temp been around your place lately?
HTML code is On
