sump pump connection
Old 02-24-03, 09:27 AM
alorenzo
The sump pump in my basement has 1 1/2 inch pvc pipe connected from the pump up to the pipe that goes out to the street. The PVC pipe is on an angle and therefore the connection with the pipe isn't perfect (some water is leaking)
My question is this: If I cut the current PVC pipe and connect an elbow to it then another piece of PVC from the elbow to the pipe, will this deter the flow of water from the sump pump to the pipe going to the street. I'm thinking that the reason the PVC is on angle is because the person who installed this knew something that I didn't.
Old 02-24-03, 09:36 AM
C
You could get a flexible neoprene fitting to join this almost perfect joint.
Old 02-24-03, 09:53 AM
alorenzo
are you talking about the black rubber flexible coupling that tighten on both ends with screws??
Old 02-24-03, 11:30 AM
C
Yes. But they are gray in South Carolina.
Old 02-24-03, 06:51 PM
Ragnar's Avatar
And since the pipe carries pumped water, no need to worry about the extra elbows... they won't hurt anything if it is easier to do the elbows instead of the "fernco" rubber coupling...
