leaky from underneath bathtub
Old 03-21-03, 04:46 PM
a_wiest
Exclamation leaky from underneath bathtub
when the shower Is turned on water leaks from underneath the bath tub. After investigation we eliminated leaking from the drain or when the water is running for the bath. But when the shower is running, water starts leaking from the gap under the tub where it meets the concrete floor. If anyone has any ideas about what is causing this and how to fix it would be appreciated, THANKS!!!
Old 03-21-03, 08:54 PM
mattison's Avatar
Could just be that the tub needs recaulked. Alot of times when it leaks only with the shower running its leaking around where the tub meets the wall.
HTML code is On
