Main water valve
Main water valve
I need to change the main water valve. The valve that controls the water flow to the entire house. Years ago I remember a friend doing this by freezing the pipe below the valve with dry ice. Is this still done or is there a nother way short of having the city shut the water off. I live in Brooklyn NY. There are tenants in the building and a long shut off would inconvenience them. Thank you for your help.
Received 1 Upvote
1 Post
Are all of you on one water meter for the whole building?
If you are, you will need to schedule a shut-off long enough to replace or repair the valve, and notify all tenants (who also may need to make plumbing repairs while the water is shut off).
If you're replacing your main cut-off, I would go with a ball valve instead of a gate valve.
Good Luck!
Mike
Good Luck!
Mike
