Catch Basin Question
Old 03-31-03, 11:04 AM
Slumlord
Hello everyone,
I have a catch basin that needs to be cleaned out and I was wondering if anyone had any good methods they could share. The place was built in the 1930's and the catch basin is outside, made of brick, and has a steel manhole cover over it for access. The water level is about 6' down. My ideas:
1. Get a bucket on a rope and try to pull the scum out. I don't know what to do with the scum though once it's removed. Can I flush it down the toilet which goes to different sewer?
2.) Add a chemical to the catch basin that will eat the scum.
I paid someone too much money last time because I didn't want to deal with it. They used the bucket method and took the stuff with them. Then threw some Lime in the catch basin and in the basement drains.
Thoughts?
Slumlord
Old 03-31-03, 01:24 PM
Mike Swearingen's Avatar
Cool
Is this some kind of grease trap?
If it is, you need to dip it out with a bucket and throw it in the trash, not in a sewer line.
Good luck!
Mike
Old 03-31-03, 06:01 PM
notuboo's Avatar
You could get a couple of bids with someone who has a Jet-Vac truck. This is a little different than a septic tank honey wagon.
The Jet-Vac has a high pressure washer on it which would make short work of any scum lines on the walls.
This would probably run a few hundred dollars, but it's an idea.
Old 04-21-03, 10:57 AM
Slumlord
Smile
Thanks for the ideas gentlemen and sorry it took so long to get back.
I grabbed a bucket, put a bunch of 5/16" holes in it, connected it to the end of a rod, and went fishin. I pulled out a couple of big pieces, but when a few large areas broke away from the wall, they sank. I dug a little more and waited for about 30 minutes for it to re-surface, but nothing. I'm hoping even a large chunk will resurface eventually. Hopefully I didn't make a bad situation worse.
The good thing was, it didn't cost anything. I still want to add the Lime though.
Thanks again.
HTML code is On
