pipe joint compound or teflon tape
Old 04-07-03, 05:39 PM
Brownthree
Which is better to use to on threaded plumbing connections...pipe joint compound or teflon tape? The plumbing connections I will be making soon will be for an above ground swimming pool.
Old 04-07-03, 07:03 PM
Ragnar's Avatar
Either one will work, but I prefer pipe dope...
Look up the topic in the search engine and you will find several animated discussions on the subject... ...
Old 04-08-03, 08:31 AM
Plumber2000's Avatar
Use teflon tape on plastic male threaded fitting.
Old 04-08-03, 11:42 AM
Mike Swearingen's Avatar
Cool
As far as the age-old argument goes about whether to use tape or pipe dope, I use silicone caulk. LOL!
(Don't do that Brownthree. Just a joke.)
It's really a matter of choice about tape or dope. I use both. They both work. Try them both, and like everyone else, go with the one that YOU prefer.
Good luck!
Mike
Old 04-08-03, 08:18 PM
refurb88
pipe dope or tape
I was taught by an old plumber to first install the tape, then paint on the pipe dope.There both cheap and the extra insurance is nice.Just a little food for thought.Good luck with your project.
Old 04-09-03, 05:54 PM
Brownthree
Thanks for all the tips as I only want to make these plumbing connections just once.
Old 04-12-03, 06:12 PM
poleaxed
speaking from expierience be careful using pipe dope on plastic to platic fitting it does a good job as a sealant but it also will act as a lubricant and may overtighten and crack the fittings.typicaly i use tef tape on all platic fittings and water type joints and pipe dope when im doing gas lines or air lines.
HTML code is On
