Which is better ABS or PVC?
Old 04-14-03, 11:19 PM
zabooger
Hi,
We are adding drain waste plumbing for a bathroom sink to our house. It currently has cast iron pipes. I read that cast iron can be hard to work with and nowdays people use ABS or PVC. Okay, I am all for that but which one is better? ABS or PVC?
Any assistance is greatly appreciated.
aloha,
Mark
Old 04-15-03, 02:19 AM
Mike Swearingen's Avatar
Cool
I have mostly black plastic ABS and some PVC for drain lines in my 1977 home.
A couple of ABS joints have just come apart over the years. Never had a problem with any PVC.
I'm not a pro plumber, but I've seen in the opinion in here that the PVC glue holds better than the ABS glue, but ABS is less expensive.
I would think that either would be fine, however.
Your call.
Mike
Old 04-15-03, 05:39 AM
notuboo's Avatar
It can be a code thing in some applications.
I'd go with ABS, but that's just my opinion.
BTW...If you are removing cast iron, just remember it's heavy. You will be surprised at how heavy if you are not prepared for it. Wear eye protection if work is above your head...Hearing protection if working with wife...
Old 04-15-03, 10:46 AM
zabooger
Thanks!
Thank you for the great input. When doing it yourself, you never know what can happen.
aloha,
Mark
Old 04-15-03, 10:48 AM
T
I think PVC looks better....
Also, since it's a bit thicker than ABS it should be a bit quiter.
HTML code is On
