replacing toilet in 5 yr old house
Old 04-18-03, 05:10 AM
C
Im about to replace a tiolet in my 5 yr old house. Beside replacing the wax seal is their anything else I should expect or run into?
Thanks
Old 04-18-03, 07:31 AM
Lew Falconer
Good morning. I would suggest you have a new set of closet bolts (hold toilet base to floor flange) on hand in case you can't re-use the existing ones. You might also need a new delivery tube from the shut off valve to the toilet. The ones with the stranded stainless steel covering are the easiest to use.
Have a good day and let us know how your project worked out.
HTML code is On
