Water Pressure
Old 04-18-03, 08:06 AM
qhang
Water Pressure
Hi,
I understand that water from the street coming through pressure regulator to reduce whater pressure before distributing inside the home. My question is, can I tap into before the regulator so that I can get street water pressure for sprinkler system?
Thanks.
Old 04-18-03, 09:46 AM
Mike Swearingen's Avatar
Cool
Yep.
Everything past the meter is yours. I recommend a separate ball valve off a T from the main line before the RPV.
Good Luck!
Mike
HTML code is On
