Flapper Likes It's Seat
Old 04-19-03, 08:54 PM
elgarc
Question Flapper Likes It's Seat
Re-installed toilet. New fill valve and flapper. All is well...except the flapper won't stay up while the tank empties. It falls back into it's seat like a brick. Checked for interference with the stainless chain. Not. Tried different places on the handle bar. No help. Kinda confusing. Got help?
Thanks,
Gary
Old 04-20-03, 06:17 AM
Mike Swearingen's Avatar
Cool
A flapper chain should be as short as possible and still allow the flapper to fully seat.
Mike
Old 04-20-03, 03:25 PM
elgarc
Righto, OldGuy. It is. Been looking in other tanks, and looks like the flapper seats are not straight toward the stool, like mine. Think I should take off tank and turn the seat?
Thanx, Gary
Old 04-20-03, 07:23 PM
Ragnar's Avatar
If you have to turn it, that may be the only solution, but you might also try a stiff plastic flapper with a gasket instead of a rubber flapper... sometimes you can get them to pull up further and stay the appropriate amount of time...
Old 04-21-03, 07:18 PM
elgarc
Talking Aha!
Well I be. Guy at Lowe's, where I bought the flapper asked if I had cut off the inner circle where the "ears" are. I hadn't known that was necessary. I did that. Works great now. Would'a been nice if that had been in the directions. Smarter now. Thanks for the responses.
Gary
Old 04-22-03, 01:34 AM
Cool
Yep. You can use the ring or the ears, but I've always found that cutting out the ring and using the ears makes a flapper work FAR better.
Mike
HTML code is On
