bladder tank empty
Old 04-20-03, 07:41 AM
jamal
bladder tank empty
Water pump would not shut off, (pretty old - 30 yrs.+), replaced it. Bladder tank at 28 psi - water pump 30/50. Worked great last night - today - no water. Water pump pressure at 5 - sound like no water in bladder tank. What did I do wrong?
Old 04-20-03, 11:08 AM
Mike Swearingen's Avatar
Cool
The air pressure in the bladder tank is correct.
With the water pressure off of the system, the air bladder should be two psi below the 30 psi cut-on pressure.
Sounds like you may have lost prime and /or you have a leak on the suction (well) side of the pump.
See www.peekspump.com for more information. this is Ron Peeks' site, and he is the resident wells-and-pumps expert.
Good Luck!
Mike
HTML code is On
