new plumbing
Old 04-26-03, 01:49 AM
grid
new plumbing
I have a concrete slab floor.I have hammered up a trench to remove some broken pipe to the bathroom.My problem is that the toilet has the same problem. Can I hook the toilet in through the new pipes I have laid for the bathroom? Do bath and toilet pipes all end up at the same place anyway?
Thanks
Old 04-26-03, 03:14 AM
poorplmbr's Avatar
Received 1 Vote on 1 Post
Unless you have a grey water system, then it all ends up in the same place but the toilet pipe must be a minimum of 3".
Old 04-26-03, 04:06 AM
grid
thanks poorplmbr.
Im using 4" pipe but i dont know what you would call a grey water area.
Greg.
Old 04-26-03, 04:39 AM
Mike Swearingen's Avatar
Cool
"Grey water" is any drain water that isn't from a toilet, such as a washing machine. Some have a grey water sump (aka dry well) separate from a septic system to reduce the load on the septic system.
Be certain that the new drain lines are tied into existing vents.
You can do a Search above on bathroom plumbing for illustrations in past posts.
Good Luck!
Mike
Old 04-26-03, 05:42 AM
grid
Cool new pipes
Thanks Mike,
We are on town sewer so all should be ok. I am wanting to move the current toilet vent as it is in the lounge which was originally a garage. I thought I should put it at the same distance from the toilet as it is now. However to do that it will have to go in the bathroom and be boxed in. It is 4" and will also have the bath,shower and basin running into it.Does it sound like Im putting to much pressure on it?Should I put another in?
As a side note I only found this site this evening and cant beleive how helpful it is. Great work everyone.
Greg
Old 04-26-03, 06:21 AM
Cool
There is no pressure on a drain/waste/vent system.
However, there are maximum distances from the fixture to the vent.
Keeping the new boxed-in dwv stack the same distance from the toilet as the old one should work fine. You can drain eveything into the 4" line, and each fixture drain should be vented after the trap.
Be sure to keep all drain lines at a 1/4" slope per linear foot of line toward the main.
Good Luck!
Mike
Old 04-26-03, 01:04 PM
Ragnar's Avatar
Well, if you are venting the toilet a similar distance as it was before, that is good, and if you are draining the other 3 fixtures into the 4" vent portion of the pipe then that is fine... that pipe will carry 216 fixture units... You are putting 5 on it... In fact, in my area you change that 4" vent to a 2" vent and it would still be fine... Just make sure everything ties into the 4" vent, not to the 4" main drain...
Old 04-26-03, 03:23 PM
grid
Wink new pipes
Thanks everyone. You have answered my concerns.Ill let you know how it goes.
Greg
HTML code is On
