Water Supply Pipes
Old 04-28-03, 09:26 AM
qhang
Water Supply Pipes
Hi,
I lived in Ashburn, VA. I am trying to run Water supply for my wet bar. Is it ok to run it behind the drywall again the foundation wall? Is it going to freeze in the winter?
Thanks.
Old 04-28-03, 11:42 AM
Mike Swearingen's Avatar
Cool
Is this foundation wall exposed to freezing weather, or is it below the frost line?
If the room is heated, it shouldn't freeze.
Mike
Old 04-28-03, 11:56 AM
qhang
The pipe is not exposed to outside temperature and between drywall and insulation. It is not below the frost line. The basement will always heated in the winter. Would the pipe be frozen?
Old 04-28-03, 01:00 PM
Cool
It most likely will not freeze, but anything is possible.
Mike
HTML code is On
