Plumbing Venting
Old 04-30-03, 06:44 PM
bigbluedude2
Question Plumbing Venting
I am renovating an old bathroom in an Very Old house. Post and Beam construction. The room size is 8X13. As it stands now, a 3" vent line is within 8 feet of all fixtures, toilet, sink, shower. The post and beam makes it almost impossible to route a vent line around the room perimeter to the 3" stack through the roof. The uprights are 5x5 chestnut and I would have to fir out the room by 2 inches to fit the vent line. The orginal bathroom that was removed worked just fine with the vent line 6-8 feet away from all the fixtures. The only fixture that meets the 3.5 feet rule from the vent will be the sink. Can I live with the toilet and shower being greater than 3.5 feet??
Old 05-01-03, 05:15 AM
notuboo's Avatar
Toilet needs to be within 6 feet and shower 5 feet.
Hopes this meets your design.
Old 05-01-03, 06:35 AM
Brewbeer
Distance from fixture to vent varies with the diameter of the the drain line.
1 1/4 inch ----- 2.5 feet
1 1/2 inch ---- 3.5 feet
2 inch ----- 5 feet
3 inch ----- 6 feet
As always, not valid in all juristictions, your milage may vary. Discuss specifics with your local approving authority.
Old 05-13-03, 04:07 AM
bigbluedude2
Thanks
Took your advice and ran the 2" line around the bathroom to bring the vent within code of the toilet. I will lose 2" in the length of the room but can live with that instead of a poor flush
HTML code is On
