Jacuzzi will not shut off??
Old 05-02-03, 06:16 PM
idreos
Question Jacuzzi will not shut off??
I have a jacuzzi type bathtub (manufactured by American Standard).
Yesterday after using it I found I couldn't turn the pumps off. The switch is a small metal plate you touch to turn the air pumps on and off.
I had to turn the circuit breaker off to turn the motors off. An hour later I found turning the circuit breaker back on turned the pump motors on again,
Has anyone had a similar problem with their jacuzzi?
Any help appreciated!
Old 05-02-03, 07:12 PM
Ragnar's Avatar
Sounds like the air switch is bad... Could have come disconnected with the vibration of the motor... Or the switch at the motor could be bad... In either case, you will have to get access to the motor side of the tub and replace the part... Call American Standard directly if you hope to find a replacement part for one of their tubs...
HTML code is On
