relief valve on pipe comeing from submersible well pump
Old 05-05-03, 03:25 AM
kvan
how can i fix the dripping from the relief valve on water line comeing from well?it looks something like a releif valve on a water heater but it doesnt have a handle or lever you can use to drain...is there any adjusting i can do or do i replace it
Old 05-05-03, 07:53 AM
KField's Avatar
First off you should make sure it isn't dripping because of high pressure. If your pressure switch is stuck closed, your pump will run all the time and could reach the 75psi that the relief valve opens at. If you have a gauge and are sure pressure isn't the cause, just replace it. It isn't expensive at all and not too tough to change.
Ken
HTML code is On
