Facuet Copper fitting and Compression nut
Old 05-05-03, 06:39 AM
jdennis
I have a faucet from American Standard that has two copper lines coming out of it. I bought some compression connectors from Home Depot, but I can not get them to tighten. I even brought the faucet with me to home depot and the guy goes slide this on and tighten. Any idea what the heck i am doing wrong here?
Old 05-05-03, 11:52 AM
Mike Swearingen's Avatar
Cool
Did you slide the nut and then the brass ring ferrule onto the tubing, and then try to tighten the fitting?
Are you holding a backup wrench on the fitting when tightening the nut?
Mike
Old 05-06-03, 07:12 AM
jdennis
OK I am a dumb azz. That worked thanks!! I saved about $75 per sink I just hooked up.
Old 05-06-03, 09:38 AM
Cool
Good for you! That's what DIY is all about (plus the fun).
Mike
HTML code is On
