Chattering Garbage Disposal
Old 05-05-03, 01:01 PM
RobertB
Our ISS Insinkerator garbage disposal suddenly began making load metal banging sound; motor turns with crank; there is nothing alien inside the drain.
What coukd be the cause. Any suggestions before I start taking it all apart?
Thanks!
Old 05-05-03, 05:12 PM
Ragnar's Avatar
You may not see anything on top of the wheel, but sometimes something can get lodged just underneath... But the chatter is also commonly caused by a "tooth" beginning to come loose... If it is more than 5 or 6 years old, I would just replace it rather than take it apart... It isn't worth the effort of working on it... If you get another one, the ISS Insinkerator is a great dependable unit... (assuming it is not the victim of abuse)...
Old 05-07-03, 11:43 AM
RobertB
Thanks Ragnar for your advice. Unit seems fairly new (came with recently purchased house, but without documentation).
I will have to dismantle unit to get better look. There appear to be two hammers that rotate inside the catch bassin. I do not see a "wheel". I suspect the top nut may have come off the shaft and is rattling inside when the hammers rotate.
Thanks for your support.
HTML code is On
