Mansfield float shuts off too quickly
Old 05-10-03, 07:15 AM
E
Angry Mansfield float shuts off too quickly
Installed new Mansfield float. The float shuts off the flow from the tank to the bowl after only 1/3 of water is emptied. How do I correct?
Old 05-10-03, 08:32 AM
poleaxed
try moving the flapper chain to the last hole (if it has one)of the handle stem this will give the flapper more lift. also make the chain as tight as possible. if that doesnt work buy a diffrrent style flapper or they make a styrophome float that can put on the chain to keep it aflaot longer.
Old 05-10-03, 01:20 PM
Ragnar's Avatar
Sounds like you bought the ultra low flush version of the Mansfield flush valve... Go buy the one that is NOT low flush and rob the plunger from it and put in on the shaft of the one you have in now...
HTML code is On
