Misbehaving water heater
I have an 8-year-old American Water Heater Co. water heater, 40 gal. natural gas. I am confident that it is their bottom-of-the-line model (inasmuch as it was put in by the prior owners of the house when the previous heater gave up the ghost a few weeks before we took possession of the house). It seems like it doesn't get the water as hot as it used to. There are 5 marks on the thermostat (Hot, A, B, C, and Very Hot), which I believe correspond to 120 - 160 degrees, in 10-degree increments. I have to set it between B and C to get reasonably hot water. Some (but not all) mornings when I get up I have to mix in almost no cold water to take a lukewarm shower. But there are other times when the water gets rather hot. Any ideas on what this could be? Could the thermostat be bad? Dip tube?
Definitely could be the diptube, but I think with those symptoms the thermostat is more likely... I personally don't like changing thermostats in a heater that may only last another few seasons anyway, but if you want the info on how to check them and how to change them, just do a search on thermostats above...
