Kitchen Faucet Leaking Underneath
Old 05-13-03, 04:21 PM
cshekher
Question Kitchen Faucet Leaking Underneath
I installed a single handle kitchen faucet (Moen) several years ago. There always was some water around the faucet base, but nothing serious.
Now the water has started leaking from under the faucet and is wetting the cabinet under the sink. Water seems to be coming from both hot and cold sides from the openings in the bottom of the faucet base.
Is there an easy solution? Thanks for your help.
Old 05-13-03, 05:49 PM
Ragnar's Avatar
Usually, you just need to take the handle off... Turn off the water to the fixture, and replace the orings under the spout... Also, you might want to get a new stem assembly while you have the handle off...
HTML code is On
