Removing scratches inside toilet
Old 05-13-03, 11:55 PM
fastnphree
Question Removing scratches inside toilet
The porcelain is scratched from a drain cleaning tool. Does anyone know how to remove these scratches? I hope they're not permanent!
Old 05-14-03, 05:34 AM
Mike Swearingen's Avatar
Cool
Get a pumice stone (available at hardware stores) and you should be able to wet-scrub the scratches off with it.
Good Luck!
Mike
Old 05-14-03, 11:04 AM
fastnphree
Thanks Mike! What a relief. So you're a self proclaimed unlicensed do it yourselfer, huh? Be that as it may, you have obviously helped out a bunch of people on this forum. I'm sure we're all very glad you're here. Thanks so much for the help. I think you deserve an honorary certificate of do it yourselfing! Or how 'bout the keys to the cyber city?! Anyway, thanx again and keep up the good work.
Murph
Old 05-14-03, 06:44 PM
Cool
Murph,
I believe in "truth in advertising", so to speak.
There are two very excellent Co-Moderator pro plumbers on this forum, for instance, who are FAR more knowledgeable than me, and I just try to fill in the blanks as another DIYer (different perspective).
There also are some very good pro plumber Members who contribute on this forum, and I always defer to the pros.
I just approach things as another DIYer, and I hope that the folks needing help understand me and my approach to problems.
Sometimes I blow an answer, and sometimes the blind hog here finds an acorn. LOL
The pumice stone (solidified volcanic lava foam) should solve your problem.
Good Luck!
Mike
HTML code is On
