no shower water pressure-just a trickle
Old 05-14-03, 04:13 PM
jbill122
I can hear pipe sounds but a little water trickled out-no pressure. This is a shower only-no faucet.
Old 05-14-03, 06:24 PM
Mike Swearingen's Avatar
Cool
Remove the showerhead and clean it out. Soak it in vinegar overnight if it has white mineral deposits clogging it.
Try the pressure without the showerhead on, to see is that is the problem.
Good Luck!
Mike
Old 05-14-03, 07:37 PM
jbill122
We tried removing the shower head-the water just trickles out of the pipe.
Old 05-14-03, 07:51 PM
Ragnar's Avatar
The next thing to check are the stems or the stem for debris and rust... Turn the water off to the house, take off the handle(s), remove the stems and check the valve for anything that doesn't belong...
Old 05-15-03, 12:37 PM
jbill122
Is there a quick explanation on how to do that?
Old 05-15-03, 01:02 PM
jbill122
Also...someone mentioned it could be a bad cartridge.
HTML code is On
