bathroom sink - stopper hardware
Old 05-16-03, 12:23 PM
lgreen1
The Moen stopper hardware in several of my bathroom sinks has worn and looks as if it needs replacing. Is there any special tool to remove the collar ? I am assuming it unscrews. Any "got yas"??
Old 05-16-03, 05:37 PM
Plumber2000's Avatar
Look under the sink, on back side of the drain where the stopper goes in at, you will see a nut, loosen this up, pull the lift rod out and this will release the stopper, then get one just like it, in install it the way you took it apart.
HTML code is On
