wax toilet seal
Old 05-21-03, 11:09 AM
harryhomeowner
wax toilet seal
How can you tell if the toilet is leaking at the seal. I just installed it, and made sure the wax was nice and warm. Pressed it into hte toilet, and dropped it in place. I am just a little uneasy, and would love to be able to tell (now rather then later) if it is leaking into the subfloor.
Thanks for your previous & future help!!!!!!!!!!!!!
Old 05-21-03, 11:45 AM
Mike Swearingen's Avatar
Cool
If a seal is leaking, it usually means some water from under the toilet on top of the floor, or at least a distinct odor.
You should be able to easily tell if it is leaking or not.
Mike
Old 05-21-03, 07:07 PM
Ragnar's Avatar
I will fill you in on how to tell if a wax seal is leaking if you will tell me how you KNOW that the light in your fridge goes out when you shut the door... ...
Old 05-23-03, 06:10 AM
harryhomeowner
Just put a video camara inside before you close the door.
Old 05-23-03, 06:25 AM
Plumber2000's Avatar
You can always crawl under the house and see if you can see water seeping into the subfloor benieth the toilet.
If you know for sure when you set the toilet, that the wax did squeeze downward, then good chance it got a proper seal.
Old 05-25-03, 05:12 PM
poleaxed
This is plumbing not brain surgery....thank God.
HTML code is On
