No water in sink after reopening shut-off Valve
Old 05-24-03, 04:39 PM
bdodd444
Here's the deal,
I closed the shut off valves under the kitchen sink to replace my cartridge. They were hard to turn, but I was able to shut the water off. When I opened them I have only a drip of water coming out!! Any ideas? I hate to replace the valves if there is an easier solution. Thanks.
Brian
Old 05-24-03, 05:22 PM
Mike Swearingen's Avatar
Cool
Remove the aerator on the end of the spout, try the water pressure without it on, and then clean the aerator out.
Good luck!
Mike
Old 05-25-03, 05:41 AM
bdodd444
No luck with aerator, still just a dribble of water. Could both valves have gone at the same time? Should I bang on the pipes to loosten something clogging the valve or pipe? Help before I do something stupid. Thanks.
Brian
Old 05-25-03, 05:57 AM
Cool
Don't bang on anything.
Turn the main water shut-off valve OFF, and take both under-the-sink shut-off valves apart one at a time to check the washers for damage or to see if any pipe debris was dislodged and clogged the valves.
Put a bucket or towel over the shut-off valves, and have someone turn the main water valve on for a second to see if it blows any debris out of the valve, if the washers are O.K.
Mike
HTML code is On
