How to Fix a Running Toilet no bulb
Old 05-31-03, 09:05 PM
iam4uk1999
i have a toilet that continues to run after the tank fills. i viewed the diagrams on how to repair, but the toilet does not use a floating bulb. how can i tell if the "floating" mechanism is not working? confused:
Old 05-31-03, 09:09 PM
Mike Swearingen's Avatar
Cool
You probably need to replace the tank water inlet valve.
Get a Fluidmaster 400A float-cup type fill valve and just follow the easy installation directions that come with it.
Good Luck!
Mike
Old 06-01-03, 07:09 AM
poleaxed
the fill valve is spring loaded. You can turn the top push it up or down and turn it back to lock it into place. This is how you adjust tank level.
HTML code is On
