Cutting terracotta to join with PVC
Old 06-02-03, 09:37 AM
Chondog
I need to join a piece of PVC pipe to a terracotta pipe. What is the best (and hopefully, easiest) way to do this?
I.e., masonry blade for circular saw, pipe cutter?, etc.
Thanks.
Chris
Old 06-02-03, 09:40 AM
Mike Swearingen's Avatar
Cool
Masonry blade would do it, and a Fernco coupling would connect them.
Good Luck!
mIke
Old 06-02-03, 09:53 AM
Chondog
Thank you for the quick response.
I'd like to ask a little followup question if I could....
Do I need to wet the blade and/or the terracotta pipe to help prevent the clay pipe from crumbling? Or, should it cut through pretty easily?
Thanks again!
Old 06-03-03, 05:39 AM
Plumber2000's Avatar
Rent a snap cutter at a rental yard.
HTML code is On
