Connecting to existing PB pipes
Old 06-02-03, 10:14 AM
Gunn-Man
My home is plumbed with PB pibe (copper fittings). The usual questions/concerns aside, I'd like to know what is necessary (parts and tools) to "T" off an existing PB line and run a new copper line. I'd like to add an ouside sink and access is no problem. I've just never worked with this stuff before. Thanks in advance!
Old 06-02-03, 08:28 PM
Ragnar's Avatar
The best way to go is to go to a supply house and tell them the size of poly and then get two adapters from that size poly to a male thread on the other side... Then cut out a 6" or 8" section, put the two adapters on and then use cpvc or copper in between the two adapters using female threaded fittings to make the transition... Then just tee off the copper or cpvc with the proper fitting... They make poly tees but they are harder to find and the ones they sell at most places are not much good, and I don't trust them...
Old 06-03-03, 06:52 AM
Gunn-Man
Thanks and a follow up
Thanks! The lines that I'm T-ing off of are to my washing machine and I'm doing it pretty close (1-3 feet) to the spigots. Now that I think about it, I'll probably terminate the poly in the manner you describe and then run copper to new spigots and T off that line. Do most supply houses have the necessary tool (I assume a specialized crimping tool is necessary). I'm in Atlanta as well. Do you have any recommended supply house?
HTML code is On
