rust around drain in tub
Old 06-04-03, 07:15 AM
BBoll
I have a stand alone tub with rust around the drain in the bottom of the tub. The drain uses a metal plug to hold water in. Can I repair the rust without removing the drain with a tub repair kit?
I was told that I might have to replace the tub.
Any other ideas would be appreciated.
Old 06-04-03, 12:35 PM
Mike Swearingen's Avatar
Cool
A cast iron tub needs to be professionally re-surfaced. This is not a DIY job, and is not inexpensive.
The drain would have to be removed to clean away ALL rust, if you tried some kind of temporary paint job.
Good Luck!
Mike
HTML code is On
