Leaky union between stainless pipe and PVC
Old 06-05-03, 05:16 AM
steir
Question Leaky union between stainless pipe and PVC
My Maxiflo heat exchanger (for the hot tub) was initially plumbed with 1 1/2" stainless. Once the stainless runs go out of the house, they're joined with pvc. The union is leaking pretty badly and I was wondering what the best approach for fixing the leak would be. Thanks!!!
Old 06-05-03, 06:11 AM
Mike Swearingen's Avatar
Cool
Is it leaking from the union istself or the threaded ends of the union?
Use teflon tape and/or pipe dope on the threaded fittings.
If the union is leaking, take it apart, clean it and align it, and re-tighten it.
Good Luck!
Mike
Old 06-05-03, 07:22 AM
steir
Smile
Thanks. I'll give that a try tonight. The leak is definitely coming from the threads. My worry is that the joint is frozen but I'll re-post if that's the case...
Old 06-06-03, 05:15 AM
steir
Thumbs up
Pulled it all apart; cleaned the threads; wrapped a bit of teflon tape and re-threaded. Worked great! Seems that the original install was cross threaded and force fit.
Thanks for the help!!
Steve
HTML code is On
