Shower leaks
Old 06-06-03, 07:49 PM
Richard 7333
Shower leaks
I have an old Price & Pfister shower set with seperate hot and cold and a seperate diverter knob. When my tub was reglazed, the guy took off the handles. When I tried to put them back on the hot water handle and the tub diverter leak. Help!!! My mother in law is flying in tomorrow morning!!!!
Old 06-06-03, 10:07 PM
tiny580
well rich there is probably a bad o-ring in that dirveter.
with 3 knobs you do not have to turn the water off to fix it.
the local hardware should be able to help you if you take the part with you.
nate
Old 06-07-03, 06:06 AM
Plumbrich
If you have the older model P.P. faucet it will be the packing on the stem.If this is the case all you will need to do is tighten the first nut on the stem and it wiil tighten packing and stop leak.If I'am not mistaken all pre 1984 P.P. three handle valves use packing.After 1984 they use O-rings you will then have to take stem out and replace o-ring.
HTML code is On
