changing leaky bath tub fixtures
Old 06-08-03, 07:49 AM
Butlergum
I need help with the removal of the stem. I don't want to break it off, but I can not get the nut to turn. What should I do?
Old 06-08-03, 07:53 AM
Mike Swearingen's Avatar
Cool
You can soak it with WD-40 or other solvent to help loosen it.
If you can get a larger wrench or a pair of channel-lock pliers on the stem cap for leverage, you should be able to turn it out counter-clockwise.
Good Luck!
Mike
HTML code is On
