adding a shower
Old 06-08-03, 10:03 AM
rdmdale
adding a shower
I have 1 1/2 baths now. I want to add a shower to the 1/2 bath. There's a wall dividing the two bathrooms. There is a sink on the other side of the wall from where I want to add the shower. Can I 'T' off the hot and cold lines to run lines for the shower hot and cold? Can I 'T' into the sink drain pipe right above where it goes into the concrete slab? Thanks, Rob
Old 06-08-03, 11:57 AM
L
Yes, and no. Tapping into the hot and cold water lines is no problem. But, the lavy drain is only a 1-1/2" line, and a shower needs a 2" line. Since the house is on a slab, you would be looking at removing some concrete to access the drain lines to install this shower properly.
HTML code is On
