C-Pvc for Sink
Old 06-12-03, 02:08 PM
T
Tao
Tao is offline
C-Pvc for Sink
I'm putting in a new sink. the existing piping is copper. Because I an not skilled at sweating the copper connections I thought I would use c-pvc instead. Is there any disadvantages or problems using the c-pvc? Should I just suck it up and sweat the connections?
Thanks
Old 06-12-03, 03:36 PM
Ragnar's Avatar
CPVC is just fine, and in fact can last as long as copper if installed correctly... You will still likely have to make a transition form the copper to the CPVC with a sweat adapter or you can just use a compression fitting to transition...
HTML code is On
