Grohe 17mm shower valve socket wrench
Old 06-13-03, 07:27 AM
tom bart
Angry Grohe 17mm shower valve socket wrench
What do you guys use to take out a 17mm shower valve. I can't find a 17mm shower socket wrench. Is there a US size that works? If not, what do you use. I have a Grohe system and I can't get the hot water valve out of the wall. I need more leverage I hope to get it out. The adj wrench I've tried is not doing the trick? Help?
Old 06-13-03, 10:37 AM
Plumber2000's Avatar
Have you tried the tub stem scokets?
Old 06-15-03, 10:00 AM
Plumbrich
I use 3/4 drive sockets for those faucets.I put the stem through the socket and use a pipe wrench.There are several faucets out there that the tub wrenches wont fit.Some of the ones that do fit are in to tight and they strip the wrench.
HTML code is On
