kitchen drain stub out with picture 2
Old 06-14-03, 06:45 AM
mmgorena
This is a picture of the drainpipe and nearby pvc piece.
Hi - before you read this I want to warn you that I don't konw the plumbing lingo so please bear with me. I just moved into a 1955 home and discovered that everytime I wash the dishes the water comes out a pipe that extends out the brick in the area of the kitchen sink. This pipe is not PVC - it is metal and looks old, rusted (extends about a fourth of an inch out, is smooth on the outside and has about 1/8" inches of worn out threading on the inside). The Ptrap and trap arm are PVC but it seems like the drain stub out is also metal only newer than the one that extends outside. (I was told the plumbing was redone not too long ago). The water comes out that old metal drainpipe at the same rate that I have the faucet on. I was told that it may be a cleanout and that if I plug it up the water would be redirected to where it should go. I went to home depot and one of the guys there told me that plugging it up might cause the water to backup, not to mention that we couldn't find either a pvc fitting nor a galvanized fitting that was the appropriate size (I believe that was 11/2").
About one foot away old metal pipe in the brick is a plugged pvc (2").
Should I try to plug up the old metal one, if so what can I use - PVC?
Should I try to connect the old metal one to the plugged PVC in the ground?
Should I take out the drain-stub out and replace it with a pvc one?
Should I call a plumber?
PLEASE HELP ME!!!
Thanks
Old 06-14-03, 12:10 PM
Mike Swearingen's Avatar
Cool
Pictures didn't make it, but I answered your inquiry at your other post.
Mike
Old 06-14-03, 01:20 PM
Plumber2000's Avatar
Send me the picture and I'll post it for you.
[email protected]
Old 06-14-03, 08:56 PM
It looks like a clean out to me, if the threads are in good shape, install a threaded plug in it, if not install a expansion plug in it.
Old 06-15-03, 08:13 AM
mmgorena
Water backs up
Thanks Mike and Ron for your replies!!
I found a plug that fits ... But the water slowly comes up the sink and backs up. Do you think augering is the next step? Is that a job for beginners, I mean since the pipe is so old?
Thanks again guys, I'll be eagerly waiting to hear the next step!!
Maria
Old 06-15-03, 08:19 AM
Yes, line needs to be cleaned out, one can rent a machine at a rental yard, and try it yourself, the machines are junk, and it might turn out you will call a plumber afterwards, it's your option.
HTML code is On
